Hey guys I try searching and could not find it so please help. What is the best location for a blow off valve if you are NA-T still using MAF? Also can I run 7psi on the stock injectors?
Why do you care about the temp of the air being vented?HTB said:I heard that the closer you put the BOV to the turbo the better. Reason being is, when the BOV is put closer to the TB you are venting out cooled air. When it's closer to the turbo you are venting air that hasn't been cooled by the intercooler. So next to TB=cold air being vented, next to turbo=hot air being vented.
Why vent cold air, when hot air can be vented. The colder the air the better the performance.SecretSC said:Why do you care about the temp of the air being vented?
gadgetSC-t
:wtflol:HTB said:Why vent cold air, when hot air can be vented. The colder the air the better the performance.
