stock gap is best. dont gap plugs yourself...because when you do gap your plugs, chances are the tip will not be at the right angle to the tip which will not be good.
stock gap fires the best and preduces the most HP. is you miss at stock gap, your ignition system is weak and you might need new coil packs. dont use NGK 3330/6097 no more, they are only a temporary solution.
