i'm running a HPF bronze disk with a RPS PP and it's holding up just fine at BPU. HPF rated it to support over 800rwhp, and i've read Matt Miller making high 9's in the 1/4 mile with it as well.. however, it's not quite up to par with the HPF Feramic as the MSP beast is using. Dusty speaks highly of the RPS carbon/carbon.
all 3 are single disc's and will support over 800rwhp. i don't think you'd go wrong with either decision.. what are your goals for the car?
-jim
If you're making that much power, a single disk isn't probably the best answer. The only answer is the HPF Feramic solution if you must have single disk. I know it costs a pretty penny to jump to multidisk ike the carbon/carbon but it's worth it in the long run if you can afford the costs up front.
