i looked, and usually for a 5 lug wheel the torque spec on each lug nut is 100 ft lbs. Is this correct? Just thought i'd post and be sure. thanks!
Chris, how do you torque your lugs in the air? I always just snug all the lugs before dropping the car and then torque them. They would only stretch if the wheel wasnt seated against the hub before you started to torque them down, right?76 ft/lbs is stock. torque them in the air so you don't stretch the studs.
You're probably right, but I don't mess around. I just grab the wheel and hold it in place.Chris, how do you torque your lugs in the air? I always just snug all the lugs before dropping the car and then torque them. They would only stretch if the wheel wasnt seated against the hub before you started to torque them down, right?
