I have been researching what wideband unit I wanted to go with. Dusty has recently (2/05) made Innovate Motorsports LM-1 available to purchase on MVP. I am really interested in this kit thaks to this and a few other threads.
When looking for infromation on the Bosch and NTK sensors I searched on the Innovate Motorsports forum and Klaus the inovator for Innovate Motorsports had some good insite on why he went with Bosch.
"The differences between the sensors are:
1. Bosch has high heat sensitivity. It needs to be actively temperature controlled while the NTK has typically a passive temp. control by holding its heater voltage constant (very simple to do).
2. Bosch is sensitive to housing temp. NTK is not
3. Bosch has about 5-10 times faster response speed than NTK due to its planar design (measured delay time between pump cell current change and sensor cell output: NTK ~50msec, Bosch < 5 msec).
4. Bosch has less than 1/2 the NTK's sensitivity to back pressure. This means the readings are richer than actual on the rich side, leaner than actual on the lean side when on the lean side when back pressure is present.
5. Bosch sensor heats up more than twice as fast than NTK. This means it's also more susceptible to heat shock from condensation water because the NTK's slower warmup allows the exhaust system to warm up before the sensor can be damaged. The Bosch's fast warmup is required for smog reasons (it's main application). On the other hand the NTK is a more open design that is more susceptible to damage when hit by debris or water when hot.
6. With respect to survivability with leaded fuel they are about equal.
For most tuning applications, specially where fast response is required (not steady state load) the Bosch is the better sensor to use. The slower response of the NTK causes 'smearing' of the values. This leads to prettier graphs. A case of pretty vs. true and real (as it's often with girls)."
http://www.innovatemotorsports.com/forums/showthread.php?t=1197
