I used 1 can of BG 44K on my 94 Supra TT. Do you guys recommend replacing oil and spark plugs after going through a whole tank of gas with BG 44K in it? Does motor oil gets contaminated? Does it do any damage to spark plugs?
Thanks,
Vitek
insert cool fact here
It's not a concern if you ran it with a full tank of gas. You simply followed the directions.
The only concern I might have would be your fuel filter. Your oil should not be affected, and the low concentration shouldn't foul your plugs. I run it once a year without any ill effects.
I use it too before I want to replace my fuel filter, but then I replace my fuel filter after running with the stuff for a few hundred miles. I've heard legends of magical results from this stuff even though I just know it cleans the fuel system well.
