1 - 7 of 7 Posts
I'm in the process of fixing a BHG.
And just wanted to mention that taking the turbo off was a pain in the ass - I even used Bishop's removal guide but still.
Well, the car has been sitting for a few months now, so it's got some rusty bits.
Meet rusty the cam:
Seems a little coolant got to the 6th cylinder:
Chewed up passage:
The 6th piston has some rust, but the walls look ok. I put some fresh oil on the pistons/cylinders to clean it up a bit and let it soak.
Some questions:
Are the cams rusty because they have been sitting doing nothing, or because some coolant got mixed in the oil? I do notice some of the oil on the head looking creamy. The rust should come off? Just need to send the the machine shop? or do I need to replace my cams?
The coolant passages on the head worry me abit. There are 2 or 3 passages that are eaten up, the one in the pic above being the worst. Is fixable or should I need to worry about this? Need new head?
x2 fuck that shif off.
Those pics make my engine look brand new compared to yours (i pulled the head off mine yesterday)
TX2K10 Beer Pong Champion
Dude, find another engine and rebuild it. That will give you nothing but trouble. Maybe find a jdm GTE and REBUILD it. The block may be salvageable but see what a machine shop says. The head is absolute trash. Find another one.
Oh, and btw, properly mixed coolant won't cause rust like that. Straight water will.
Always playing catch up
jebus man, I let my car sit for 2 years and then pulled everything and it didn't look even close to that bad
you must of had a lot of water in that thing
<l><l>
So from the responses..my head is dead - shouldn't even take it to the machine shop?
I've had the car for about 3 yrs and most of it's time it has been either at the mechanics or parked. I'm guessing the previous owner/s didn't use coolant or flushed the cooling system - and now I get the end results.
I didn't have much water in the cylinder - probably dried up over the months or it seeped? down past the rings and down to the oil pan. I still need to check the bottom end.
1 - 7 of 7 Posts
