1 - 10 of 10 Posts
regretfully supraless
My temp gauge has not spiked at all, but when I cut off the car after driving a long time, I can hear gargling of coolant...I don't have the $ at the moment for a HG job...is it blown? My oil is not milky and my coolant is not brown...am I just overheating?
I would check the smaller and easier first. I am giving you this advice 'cause i was given the same advice with a similar problem. Saved me a lot of money. I was ready to pull the head off.
I wuld check for leaks, Air in the system, and the most important of all, the condition of the radiator.
My radiator was brand new, and after months, it started overheating. I could not figure it out untill last weekend when I really delved into it.
Here is a post I made. You can follow the advice I was given and the fixes I have posted.
If you are hearing garglin after driving, it could possibly be coming from your coolant overflow tank.
A possiblly bad Thermostat or Partially blocked radiator.
Replace your thermostat, and then flush your system using any of the coolant flush chemicals.
I used Prestone's Super Flush.
http://supraforums.com/forum/showthread.php?s=&threadid=266847
It is a brand new Koyo radiator. But I will check everything you said...b/c I don't really have symptoms of a BHG.
Mine was a Koyo as well. Luckily I bought it from a place where it has a lifetime warranty so it did not cot me a penny, just my time.
BTW, When yo replaced your radiator, did youflush your system completely??
I did not do it to mine, and I think that is what came and bit me in my @#@$$. :)
Well, my boyfriend did it while I was at work...I would assume he flushed it. But I might do a complete flush w/ chemicals now anyways...
How long ago was the flush done? After you initially drove it after the radiator was installed, did you recheck the coolant level? You may just need to put more in. Do a leakdown test just to make sure though.
My guess is thermostat. When the system was flushed was it replaced? If the jiggle valve is not placed at the top (or is it bottom?) then you will keep getting air in your system, hence the gurgling.
Jiggle valve will be on top.
are you using dealer red antifreeze..strongly reccomend it
1 - 10 of 10 Posts
