Yes we are still up and running, we just recently moved the shop and downsized a bit, the old shop phone number is no longer working. You can order all the parts direct off the website. We have more new custom parts being added to our store, the new website will be up shortly. PM or email me if you have any questions.
BTW those knock off DDP's are terrible, they are made from the thinnest cheapest SS thats out there, you can almost crush the pipe with your bare hands!!!, thats also assuming the holes are drilled in the right place and you can even get it to slide on the turbo studs. Also the divder plate that is missing is the most important aspect of the DDP, the China made knock off's have not been able to match the accurate and percise fitment so they just leave it off. We have gone to great lengths to ensure the tightest seal possible to avoid excessive exhaust leaks and still leave adequite clearence for heat expansion, just taking a piece of square steel and welding it on will not make a proper seal and functioning DDP. The CT26 turbine housing has a tapered section and some machined grooves that a quickly made plate will not fit....or seal making the car sound like a tractor...but what do you expect for something that costs $40 to make per unit landed in the USA??
Randy
[email protected]
bicperformance.com
