You own a supra so lets get the idea of "replica" out of your head.
😂I'm forced into replacing my brakes because they are "worn and warped." To what extent? I'm not sure. I don't really feel any issues while driving, and my non-mechanic eyes don't see anything other than some rust, but I will take my mechanic's word. I don't want to spend a good amount of money on replacing small NA brakes since I will eventually upgrade to big brakes in the future anyway. I might as well do it now, rather than paying twice. The thing I was wondering is if I could get away with some sort of larger brakes that (yes serve their function) but also look good without breaking the bank. The general gist seems to be that there aren't any big brakes that aren't made for non-tracking purposes. I see big brakes on a LOT of cars around here, and also on classic JDMs (that are clearly garage decorations that see sunlight once every 3 months). None of these cars are tracked. So I thought that maybe there may be some sort of non-tracking alternatives that are cheaper since they aren't so performance focused. Probably not though. It looks like people just pay the full cost, and then not use them for their intended purpose.
With that being said, there are multiple retro fits of OEM brembo brake set ups from other cars that work on the supra.
-17z from VW, Porsche & Audi SUV's.
-Mustang GT350
-Jeep Grand Cherokee SRT8
These all work in conjunction with Lexus IS-F rotors and there are multiple people that make brackets to install them on our cars and you can get aftermarket SS lines.
If you'd actually like to improve your braking performance with safe and proven parts combos, try these:
-'95-99 Lexus LS400 (Celsior) Aluminum 4-pot fronts w/matching rotors; these OE LS400/Celsior parts bolt right on and are an excellent improvement in braking and appearance for the money spent. The caliper face is blank so you can put whatever decal or etching you want on it. Better wheel clearance than JZA80 4pots too.
-JZA80 iron 4-pot+2pot rears w/matching rotors; timeless proven performance and appearance but not very wheel-fitment friendly due to large calipers. Many BBK friendly wheels will still need spacers to clear stock JZA80 4pots.
-SRT Brembo adapter kits. I'm not sure if the Dodge SRT8 Brembo 6-pot calipers are available or common down there, but it's a very popular upgrade up here. Usually these will be sold as a bracket kit or brackets+lines and you'll source your own SRT8 Brembos. Most of these kits use Lexus IS-F rotors so you get the exact matching Toyota 60.1mm hub centerbore and 5x114.3 bolt pattern. I'm pretty sure that's the kit you've got pictured in your OP. Depending on the kit you buy and whether you source the SRT8 Brembos from a junkyard for cheap or buy brand new, these run $2000-$3000 USD total front & rear, and get you Brembo BBK appearance and damn near Brembo GT BBK performance.
Proper BBK's that aren't as expensive as Brembo/Stoptech but still are reasonably good value:
-Ceika
-KSport
-AZ Performance+Wilwood
I'll keep these in mind when looking around, thanks!
Use the search function, there are some threads that will help with more info for each set up.
Seem like most of the members (with high post counts) support OEM TT brakes over BBKs.
You won't like this answer, but you're about to waste a lot of money. Upgrading from NA brakes is a good step, but the stock TT calipers/rotors are excellent at doing their one job.
Well, this is a part of my research stage. I haven't locked in anything, and just getting some Supra drivers' thoughts and knowledge on the topic.
And if that BBK can actually do what it looks like it can do, you're only ever going to use 25% of its ability (on the street)? SMH
Funny you mention this. I don't know how common BBKs are over there, but I see BBKs all over here. And they are mostly on cars that are clearly used as garage decorations. It's not that uncommon. I will start to ask people why they are running BBKs now and see what they say.
There's no 'economy' or 'street spec' to anything except maybe brake pad selection.
Yea, it sure seems that way. I'm clearly new to this topic, so I am still looking into it. I'm surprised at how common they are here locally, despite their prices.
So if all you want is appearance, just get the bullshit plastic caliper covers so you're at least keeping OE quality factory brakes.
I'll never go that low hahaha I wanted a middle ground where the brakes are large, but idk something like 30-40% cheaper than Brembos/Wilwoods
