1 - 4 of 4 Posts
89 Turbo
Hey, Me again now that the engine is out I have a new parts list.
Along with Dr. Jonez
Dr. J needs
-timing gear cover-> block gasket, 11312-42010 (be a 2
piece)
-oil pump shaft seal, 90311-42003
-crank shaft seal, 90311-52003
-water pump->timing gear cover gasket, 16124-42010
-water pipe->timing gear cover gasket, 16347-42010
-hatch weatherstripping/seal, 67881-14110
-7M-GTE sticker on the cam cover, couldn't find the
p/n
- exhaust manifold gasket, 7MGE (yes, 7MGE. it's a
better one), 17173-43020.
I need
For a 1989 Supra Turbo
90105-10042 BOLT, FW LIST 1.11 COST 0.82 X 8
90119-08322 BOLT, PP LIST 0.74 COST 0.55 X 6
90363-12002-77 BEARING,PILOT LIST 9.36 COST 6.92
90363-45012 BEARING, TO LIST 31.41 COST 22.99
31250-14183-84 DISC CLUTCH LIST 86.42 COST 63.78
31210-14150-84 CLUTCH COVER LIST 92.45 COST 68.23
31264-14040 SPRING, LIST 15.03 COST 11.12
90201-45023 WASHER, LIST 2.00 COST 1.48
90520-67001 RING, LIST 2.74 COST 2.03
90206-72001 WASHER, LIST 1.00 COST 0.74
90201-71001 WASHER, LIST 1.26 COST 0.93
96152-00450 RING, SNAP LIST 2.06 COST 1.53
Along with
New engine mounts
Will be returning the privies bearings I bought and buying new ones (of a different size). As soon as I find out the correct size I need.
Also I know there are things I’m forgetting as soon as I remember I will POST.
Thanks again.
11312-42010 Gasket, List 3.34 Cost 2.53
11313-42020 Gasket, List 4.40 Cost 3.38
90080-31022 Seal, List 8.72 Cost 6.45
90311-52003 Seal, List 16.78 Cost 12.41
16124-42020 Gasket, List 4.40 Cost 3.38
16347-42010 Gasket, List 2.72 Cost 2.00
67881-14110 Weatherstrip List 62.03 Cost 46.75
11291-42020 Plate, Emblem List 1.31 Cost 0.97
17173-43040 Gasket, List 29.14 Cost 20.52
12361-42050 Insulator List 141.90 Cost 104.93 Ea X 2
1 - 4 of 4 Posts
