1 - 3 of 3 Posts
Okay soo I made a dumbass mmistake about one week ago I know you are all gonna facepalm but I was using engine cleaner and after, I used a hose to wet down where I cleaned I THOUGHT I was being careful enough but apparently not. Now my car has a miss at idle,hesitates and shudders when on the throttle and is going through spark plugs like crazy [on my 3rd set now]. When I replaced them the first time the car ran fine for about 3 days then the problem came back. I changed them again today but this time it didn't clear up. Please help me outt. Read my codes and got 12 and 13
unhook cps connector and blow air into connectors(if turbo)
unhook ignitor and blow air into connectors
unhook distributor connectors and blow air into it(if not turbo)
remove distributor cap and inspect for water...if water is found replace seal and reinstall(if not turbo)
also try removing the ignitor and cleaning the grounding points with sand paper
metal to metal is always a better ground
1 - 3 of 3 Posts
