1 - 4 of 4 Posts
Just got the trans built and will be installing it in about 2 weeks from now. I am runng two b&m coolers and an additional external trans filter. I just installed a new trans in our typhoon and i was told obviously not get on it but to heat cycle it a few times up to 50 miles and dump the fluid. After that drive 200 miles and then dump it again and change the internal filter and then it was good. Is this how you would recommend to break it in with your trans? What temp range do you reccomend? How often should the internal filter/screen be changed or cleaned?
I was told by Chris @ Performance Motorsports there was no break in period Don't know if that has changed or not.
I don't understand why Boostlogic has not chimed in on this seems important. :dunno:
ok thanks! Also i was wondering has the pump been changed or modified? How much line pressure is being put out?
1 - 4 of 4 Posts
