1 - 15 of 15 Posts
Edge On The GE-T Epidemic
start with driver side rear , Passenger rear , driver front , Passenger front. Its what iv always done. Havent heared anything diffrent.
Lagmeister
usually its actually the opposite of what your dad has said. You want to bleed the line furthest from the master cylinder first, etc. till you get to the shortest line (drivers side front)
so the procedure would be
RR, LR, RF, LF
Newbie
You got the driver's and passenger's side confused. This is the sequence:
1. passenger's rear
2. driver's rear
3. passenger's front
4. driver's front
5. optionally bleed the abs (search on that whether you are tt or na)
Lol mike , i been drinking..
SupraCop
Discussion Starter · #10 ·
I did it twice all the way around. the pressure got better but it still isnt where it should be
if i pump the brakes once the air fills up, but the first time doesnt have any pressure.
I might look into those speed bleeders which one did you go with michawlvanle and do you keep those on your car perm. do you have to cover the end with a vac line or something of the sort
Newbie
Go to speedbleeders.com and you can search for your car type. It depends on whether you have an NA or TT as I believe they have 2 diff bolt patterns. I permanently put mine on. It also helps if you buy their vac lines and a "ziplock bag". You can do it totally by yourself.
Newbie
nj94supratt said:
i ordered the speed bleeders. and I bleeding line and the bag. 42.00 priority.
It said they come with dust covers too so I should be fine. did this clear up your problem.
Yea, the problem I had before was air keeps going back in. We bled it twice and the pressure still wasn't as firm as we wanted it to. After getting the speedbleeders, it was great. You can literally do it yourself.
Just remove the 4 stock bolts and install the speedbleeders. Then crack it open about 1/2 turn, install the vac line to the bolt and the other end to the plastic bag. Then turn on your car, and start pushing on the brake pedal slowly. About 4 push should be good. Then go to the next one. Just be sure you keep refilling the reservoir.
The nice thing about this thing is it's a one way valve. Fluid goes out, but air doesn't come back in.
1 - 15 of 15 Posts
