1 - 19 of 19 Posts
Hello Curt
I have done a search for this but there is no definite answer. Since you are working in Toyota, you probably can help. Here it goes
The O/D light on my dash has been blinking a code 89 since few months back. I have tried resetting ecu but to no avail.
Any idea what is code 89? Someone in the forum has mentioned it is 2 separate codes but i dont think so.
My car is a 93.5 mkivTT japspec
Thnx guys I'll check to see if this is my problem..
And I was getting ready to swap trannys.
You may save me some $$.. if you guys do I am buying you both dinner! :bigthumb:
Discussion Starter · #17 ·
Curt Aigner said:
Trac And Abs Ecu Are Located On The Passenger Side Footwell Area
You mean is the other way round? Trac ecu is behind stereo then?
If thats the case i may be getting somewhere. See I have checked the ecu at the passenger footwell and secured the socket to the ecu a few times, reset the ecu.... but that damn o/d is still blinking never ever as merry.
I have not check the ecu behind the stereo... I hope i will find some loose cables this weekend. Finger crossed
1 - 19 of 19 Posts
