1 - 13 of 13 Posts
EchoDeDupra
Today, I swapped my top pipe on my stock tt's with a greddy type-s on it for a blitz ss bov.
The first thing that I noticed is that it sounds like I am having compressor surge. I loosed the valve, but I am still getting it.
Can any one offer any ideas? I never had compressor surge with the Type-S, and I am using the same vacum line :)
EchoDeDupra
well... I think it only happends under half throttle driving...
i.e- I did a wot pull on low boost to 14 psi and it released with a pshhhhh and no compressor surge
NastyOutTheHole: I swapped the type s for a blitz...
I'm just curious if this is normal... I think I'll try loosening the spring a little more.
(It sounds like an hks ssq)
quick question does the compression surge sound like a tie fighter sound (star wars)? I think I have it with my apexi twin chamber kit..... I only get it at half throttle too... 3rd gear around 40- 60mph with 7 psi of boost.
I let off....the throttle.... no bov sounds (stock or apexi) and just the wooooooo.
Replacing my apexi for an hks ssqv.... prolly welding the flange on the turbo to fender pipe near the turbos. Will that solve a compression surge problem?
Mike, compressor surge goes like.........cha..cha..cha...cha
I have the same problem with my Blitz, you will just have to learn how to control it.
Jason
there is nothing you can do about it the HKS SS BOV is known for making some compressor surge on stock twins...
just like hot soup said you just need to learn how to control it...i have it on my bpu 6 spd and i notice that it only does it when i let off the throttle while i wasnt under boost...in other words...only if i am still showing vacuum while i am pressing lightly on the throttle and let off do i get the surge...if i go into boost slightly it wont do it..i will get the signature HKS chirp as i call it
they say compressor surge is bad for the turbos which is true but what about if it only does it lightly..does it do much damage??
anthony
J-
I was getting surge w/ my DD and I loosend up the spring on the BOV, and Viola! No more surge....
Try that...
J
1 - 13 of 13 Posts
