I have a full blitz nur set, but when im driving it hits the rear dif case or brace w/e what can I drap the exhaust in that wont burn of put on those brackets to stop the rattle?
Suprajjang said:are you driving around with the silencer in? The only way my nur spec rattles is when i have the silencer on
Supra Junky 101 said:Mine doesn't move at all, or rattle for that matter.
NJsupraA70 said:It rattles(rubs) against the subframe next to the diff. because the exhaust is slightly too long for the 7m downpipe. The nur spec was originally designed for the 1jz car. - Steve
MK3Brent said:DEI Heat-wrap will not burn, and if you're lazy you can just make a cushion out of it.
