1 - 13 of 13 Posts
· ΣΦE Member
For all you guys who are running the Nur Spec. I bought mine used and there was no gasket between were the midpipe would mount up to the "downpipe" Did it come originally with it? If not did you buy one?...Im think about just using that exhaust leak sealent and putting a band around the end of my exhaust before mounting it up. Thoughts on this? :dunno: Im planning on doing this tomorrow afternoon so the quick the response the better.
Thanks guys!
· ΣΦE Member
SupaSupraSE said:
blitz sells their exhausts with all of the necessary gaskets, etc. for necessary installation of the cat-backs.
yea i know but im lookin for something quick and i was just checkin. Think ill just use that exhaust leak goo...
· NA-T member
Mine was bought used and it didnt come with anything, bolt or gaskets.
When I got it it had the red liquid gasket on it. Im guessing that worked fine before.
Im going to use copper gasket sealer or something like that. If its bolted up tight it should work fine.
1 - 13 of 13 Posts
