The SBC-id it pretty much a updated DSBC. Most of the control functions are exactly the same. But now you can read boost in PSI and interact with the power id thru the neat little display. I actually used some DSBC tuning instructions since there wasnt any translated instruction around when I installed mine.Kevin Hoare said:Does anyone know if it uses the same solenoid as the DSBC? I wouldn't mind upgrading, but only if it used the same solenoid and wiring connection.
Do you know if the hookup to the solenoid is the same? (Is it the same solenoid and wiring harness?)qualen said:
Not sure which functions you are referring to, But I use the SBC-id as my boost gauge and it has peak hold. And it tunes the exact same way at the DSBC.TonyG said:qualen
how easy are they to tune.
Are they comparable to the funcions of the Apexi meters??
RecKleSs said:
