block boring, decking, and torque plate question
1.9K views 12 replies 2 participants last post by  Boosted Rooster
#1 ·
I have my block out at a shop right now to be bored, and they are currently waiting on a torque plate to be delivered before moving forward with the bore
Then the thought occurred to me, I haven't decked the block yet...I was planning on doing it myself, taking off about .003-.004 to remove a slight warpage on the outer edges, and also some gouges made by the head gasket.
Will this be a problem for the bore if the deck surface will be different on the assembled engine then when it was bored? I would think that the block would flex differently with the freshly machined deck, wouldn't this throw off the bore?
I'm thinking of telling them to bore it without the plate, whats your opinion on this?
Obviously the best thing would be to deck it first, and bring it back, but the shop is not nearby, it would a ton of driving for such a small detail.
#4 · (Edited)
How much will your machine shop charge to resurface the block? Only reason I ask is because I tried to use the CNC end mill at work to resurface a 3cyl jet ski engine and the results were less then desirable.
*edit* It might be possible with a large cutting head, but I would think the cost of the tooling would out weigh the savings of doing it yourself.
#5 ·
Hmm, I assume the end mill was much smaller than the deck, requiring multiple passes? I get the best surfacing finish when I do it in 1 pass with a single point fly cutter, consistent cut marks, and no trail left behind from switching positions
I'd rather not pay them to do to things I can do myself, I'm on a bit of a budget with this build
I realize I'm splitting hairs with this, the main reason I'm asking is I already told the machinist to wait for the plate to arrive, but doing so will give me another week or so of downtime, I'm considering telling him to go ahead and bore it
#6 ·
Well if your deck is true it shouldn't affect it if you bore it first. If the deck is not true, when you bolt the torque plate it it could skew the bore.
#7 ·
That's what I was thinking. The deck appears to have warped upward slightly on both ends, the gasket gouges are deeper on the ends, and if I run a dial indicator on it, you can see that the ends are higher by a few thou
this is the second 2jz block I've seen do this, it's possible they all do
#9 ·
my largest endmill is only about 1.25 inch, then I have some shell mills of larger diamters, but they dont cut well... when I deck a large surface like a block or a head, I set my fly cutter to cut about an inch or so bigger than the block surface
