My machine shop reached out to me and told me That as he’s working on the block he noticed that one of the stud holes has a stress crack going into the water jacket.
I need some honest opinion from people with knowledge
What can be done ?
Is it Ok to keep and use this block as is ?
Is there something I can do ?
Anyway you can post a picture of it???? Would likely go along way in getting someone to comment on it....
Ok. I’m back and I got some pictures. Let me know what you guys think
Go - No Go
Goal with this engine would be 20-25 psi
everything in the engine it’s new for the exception of the crankshaft and valves
How are the water jackets (the hot dog looking ports)? Those are more likely to fail.
Super Moderator
I've ran several 7M blocks with similar cracks into the head stud holes, one of which I ran at about 400whp for ~25k miles. I ran ARP head studs, and I torqued the bare stud itself into that hole to about 10 ft-lbs just to ensure it wouldn't back out. Then I marked the top of the stud and the nut once the head was torqued down so that I could visually check and make sure the stud and nut didn't back out or loosen up at all any time I had the valve covers off. Other stuff killed that engine before the crack became a problem.
