After ideas and opinions. This is a bit long winded but I want to pass on as much as I know about the problem. I appreciate anyone who can offer help - thanks.
My car is a JDM 95 TT 6spd Supra and had been running well with no problems at all. The car had FMI, AVCR - boost controller (1bar), cat-back exhaust, HKS pod filter, mapped ECU (Sard). I took the car in for a service and had new spark plugs installed, new timing belt and adjustable cam gears fitted and all the usual fluids replaced. The car on the dyno made 320hp at the wheels and a A/F of 10.5:1.
I drove the car home on the highway and after accelerating(not WOT) from some traffic lights the car at around 4000rpm hessitated made some rattling type noises (bad misfiring?) and then blew smoke out the exhaust with a bang!! I had never experienced that in any car so I had no idea how serious it was but I knew it couldn't be good. The car still ran so I limped it home.
I took the spark plugs out and found 4 of the 6 to have chunks of missing insulators with 2 of them having melted and damaged electrodes. (If people are interested I can post some photo's). I did a compression test and found 2 cylinders to be well below normal and so I did a leakage test. Found one cylinder to have valve problems and No.5 blew straight into the sump (toast!!!).
I took the turbo's off and found No.2 had lost it's exhaust wheel completely and No.1 had some missing fins. In front of the first cat was bits of turbine and some fragments of spark plug ceramic.
My first thought was what had changed from driving in to the service and then driving out:
- Spark plugs were IK22(OLD) but were changed to PK20R11(NEW)
- Cam gears fitted (Titan cam gears) 2.5 markings Advance on the inlet and 1 marking of Retard on the exhaust. (not sure but I think 1 marking is 2degrees???)
- Timing belt fitted
- New timing belt tensioner fitted.
- Fuel filter/oil filter replaced and new fluids throughout.
I do have some additional information but I'd like to hear what opinions people have without me swaying your opinions with possibly incorrect information. Thanks again.
