1 - 7 of 7 Posts
I'm buying a MKIV with a blown engine and hurt stock twins. After rebuilding the engine, should I bother sourcing stock twins or just do a budget small single setup?
Car will eventually be singled, but I'd like to take it slow as this is my first MKIV.
^ WERD, If you are going single anyway, don't waste the time & money going stock twins and then single. go straight for the good stuff. always do it right the first time, you end up saving money by not having rebuy & upgrad parts
If your planning on single turbo later why waste your time and money with the old twins?
Senior Member
I disagree. I love the twin turbo setup. Especially for your first mkiv. I'd say you should get a feel for the car. However, I have have to admit over the last year with my supra, I want to a single turbo kit or the big hks twin turbo setup.
OG
When you yank out the engine and see that even with the engine outside of the engine bay, it is a PITA to remove the stock twins, you will see that single is the only way to go.
I wish I'd done it when I blew my engine.
Cheers
Rich B.
1 - 7 of 7 Posts
