1 - 8 of 8 Posts
I recently did an oil change on my 87 NA. I only until now got around to disposing the old oil when I noticed at the bottom of the pan little specks of green...looked a lot like anti freeze. There are no other signs of a head gasket issue. Although I did have to add antifreeze in the resivor 2 times. I thought nothing of it cuz I recently changed the rad. I checked the resivor and no traces of oil in it as well the oil is not foaming up. Anyone have and ideas??
after driving open your hood and check to see if the resivor spit out water or not, if it is spitting it out on your radiator thats a hint of a possible bhg
no it does not do that...like I said before the car runs fine...nothing out of the ordinary....does not over heat and no boiling fluid.
coolant or water would float on the oil so i dunno about green specs on the bottom of the pan. to tell you the truth i wouldnt worry about it.
shit! :| :lol:
same thing ;)
Shop Tech All Around Auto
Could be that you have a little coolant leak, and a couple drops got in the pan while you where changing the oil?
1 - 8 of 8 Posts
