1 - 11 of 11 Posts
REVTECHRACING.COM
im about install my t67dbb and wanted to know where evryone runs the coolant lines and how? any pics would be great to help out a dummy and for future people installing these turbos.thanks. :ugh2:
Ive heard from Kean to use one of the coolant ports on the upper water neck for the feed, and the water pump water line for the return which is right beside the lower rad hose.
WI-FI FTW, GTFO fuse box!
I just got done doing the EXACT same thing w/ the same turbo :) With the advice of Woon, I used the nipple on the water pump for the feed and the nipple on the hardpipe that goes from the water pump, around the block and enters the oil filter area for the return. This nipple is located near the pass. side firewall. It is the one that USED to feed the stock twins.
That is exactly how i have mine ran.
I also ran my 74 DBB from the water pump nipple......
I like nipples.
Post some pics of the rear return hose. id like to see how its routed.
wouldnt it be kinda close to the dp?
You have 2 feed lines being used then? The waterpump feeds then you say the one that used to feed the stock twins???
I have the waterpump as the feed and then into the stock waterneck for the return.
that is the 2 i used but i kinda butchered the connections. its a temp. for now. anybody have a way of making it look neat? any pics or what fittings to the turbo then back to the coolant lines they used?
No problem, just trying to help!
vnt :bigthumb:
1 - 11 of 11 Posts
