these bolts keep coming loose. What could be the problem? I'm not even boosting much at all
Are you using bolts or studs ?chitwnsazn said:these bolts keep coming loose. What could be the problem? I'm not even boosting much at all
29ft-lbs should do it.michaelvanle said:.... I finally used a torque wrench and torqued it down good. It hasn't come loose since.
I dunno. Before I hand torqued it using a regular old wrench and a hammer. It still came loose. When I actually use a torque wrench (which is longer and has more leverage), it stayed good.greggf said:29ft-lbs should do it.
It's not clear what you mean by "torque wrench." I take it to mean a wrench which allows you to measure and control how much force is applied to a fastener. Fasteners that attach to the head should be tightened to spec. per the FSM. Overtightening can cause structural problems when metals heat up. I have found that by letting the properly torqued fasteners sit for a while then re-checking them gives good results. Gaskets do tend to "relax" a bit after pressure is applied.michaelvanle said:I dunno. Before I hand torqued it using a regular old wrench and a hammer. It still came loose. When I actually use a torque wrench (which is longer and has more leverage), it stayed good.
That is correct, you can get them most anywhere that sells hand toolsgreggf said:It's not clear what you mean by "torque wrench." I take it to mean a wrench which allows you to measure and control how much force is applied to a fastener. .
Yes, I know, I know. It sounded as if he was just referring to some big-ass, long-handled wrench - something that generates torque, but doesn't measure it.TooJayZee said:That is correct, you can get them most anywhere that sells hand tools
greggf said:Yes, I know, I know. It sounded as if he was just referring to some big-ass, long-handled wrench - something that generates torque, but doesn't measure it.
