627,2rwhp on pumpgas
Hi guys, my supra has become alitle bit strange.
First the idle sometimes "jumps" between 400 and 800 rpm at idle, just upp and down for a few sec then i stabelises (spelling?) this happens like 3-4 times under a 20 min period.
Second, the boost. Last week when I drove the supra home from my dad it didn´t boost over 1,1 bar (16 psi). And I went for a drive today and the same problem appaird (spelling?) again. If I turn my boostcontroler of it runs good (0,9-1 bar=13-14,5 psi)and if i set it at low boost mode it boosted 1,1 bar= 16psi (should boost 1,2bar=17,5 psi and if I set it to high boost mode the boost will only go up to 1,1 bar=16psi (should be 18-19 psi)?
I would be realy greatfull if you could help me with this, it´s realy irritating.
i get that jumpy idle problem sometimes also...well lately i have noticed it and i am wondering what this is as well...i am pretty sure one of my o2 sensors is bad..but it seems that you might have a boost leak somewhere...it seems when i tried to get anwers for my unstable idle people would always say i had a small boost leak somewhere...i cant find it..but im goin with fmic and hardpipes soon so its not priority for me right now
Ant
Idle up/down is caused by the A/C cutting in and out. The ignition control module speeds up idle anytime the A/C compressor electric clutch cuts in. This is done to prevent the compressor from loading down the engine and ensure adequate RPM provided to the A/C to provide effective cooling. Without knowing your boost controller type and the absolute settings I have no idea why boost will not go over 1.1 BAR. Stock turbos should be able to produce 1.2 BAR easily. They start getting inefficient above 1.2 though.
Boost4fun
Agreed.. Give us some more details on your mods ;)
With the idel: Just check it easily by switching off the A/C and see if the idle #´s are steady then. If yes it is the A/C comming on and off. If not maybe the iac motor?!
Gerd
The idle was not the A/C, a hose from the BC was loose. When it was hooked up everthing worked just fine :). Thanks for you answers
