1 - 12 of 12 Posts
heyooo!
So i needed a new HG and got a Greddy 2.0mm. Before install the CT26 was
putting out around 11-12lbs with a Profect B spec 2. I had my mechanic install the
Head Gasket and that workes awsome now, no issues... EXCEPT, i make stock
boost. It wont boost past stock, and is consistant everytime.
I checked the vacume tubing a couple times, checked all the wiring, I even tried
swapping out the computer part of the BC with a new one and still got nothing
any different. So im out of ideas....any help?
when this baby hits 88mph
well since someone was in there, id take a look at that again. sure it isnt something silly like the hoses on the solenoid are reversed?
oh that thing has been checked so many times, im sure its right. ill just have to replace the solenoid when i get the money, do you guys think I should stick with the Profect B?
yeah well if there was a boost leak wouldnt i be in consistant? its very consistant, it always boosts as if it were at stock
Stormcock approves
I have the Profec B and have had no problems with it. It is not prone to spiking. I have more of a problem with boost creep really, but that's cause I run an upgraded CT.
Hey guys,
I bought my first Supra a couple weeks ago, I shold be reieving it this week......I really hope! At the latest next week. Its estimated around 450 HP, so my guess around 400 at the wheels, that should be a good estimate.
So, I'm a little knew to all this electronic stuff, so at the moment is has:
TRUST GReddy Rebic LC
HKS manual boost controller
So pretty much from what I read the TRUST is pretty much out dated, but some others seem to like them still, not sure what to do with it. So I guess I will go with a fuel cut off, turbo timber, and electronic boost controller. Other suggestions? Boost guage, read that the stock one does not read true, is there a in dash replacement, or no? Just stick with a aftermarket pod mount one?
So I'm looking for suggestions. I've been reading a lot on the forums, but can not come to a final conclusion what everyone suggests.
1 - 12 of 12 Posts
