1 - 4 of 4 Posts
hello anyone know of a good manual boost controller that really hold boost like if I want it to run 17 psi it will run 17 psi, well I not trying to cheap tho I already have a gredyy profec B install but it will make the car run 14 psi on first 16 on second and 18-20 or third
also what do you guys like more open air intake or stock ait box with K&N replacment filter
Thank you
You might try a hallman boost controller http://www.hallmanboostcontroller.com . I have one and it works really well. You do have to fiddle with it a little to get to the boost you want, but once you get it set, it is very good at holding the pressure right where you set it. Also remember that if you are on stock twins, depending on how you configure the hoses, you may not get full boost on the first turbo alone. Another thing to remember is that on some cars, if the wastegate spring is not strong enough, the wastegate can start to open just from the exhaust pressure at high RPMs and caust boost to fall, so it isn't always the fault of the boost controller.
Senior Member
No boost controller will stop boost creep on a stock twin car when cats are removed and a downpipe with high flow exhaust is installed.
1 - 4 of 4 Posts
