Anyone comment on if it is normal for these 67-71mm turbos to drop in boost 1-2 psi by 7000rpm? I have done everything I could think of and am not sure if this is normal. I am trying to push and maintain 30psi.
- No boost leaks found up to 20psi
- Backpressure at 7000rpm is about 20psi
- I've tried two different boost controllers, have not tried the AEM with custom duty cycle at high RPM
From searching, it looks like many others exhibit this. I haven't tried boost above 30psi yet, but these 67mmm turbos can handle 40psi or so, correct?
