1 - 3 of 3 Posts
will start off i just change my sparks plugs got them ngk 2330 and now my car won't boost 12lbs... it's just going up to 8 now... so i lost boost... and i check most of my vaccum line so far so good could it be the spark plugs???? spark plug wire??? my gap was at .031..... this really sucks cause now my car is not where i want it to be.... my mods are 3in exhuast, intake, and was suppose to be doing 12lbs boost but now only 8lbs... so what other problem should i check???
Supra Enthusiast
Always go back to the area you were working. You most likely took out the 3000 pipe and other ic pipes, so start there. Pay close attention to the TB to 3000 pipe cupler. Other than that, I would close the gap on the plugs a tad more
Escaped from infinite lag
I dont know if you have considered, but the stock CT doesn't hold boost at higher rpms. I set my MBC to ~1bar and it always dropped off at redline to not much more than 10psi
1 - 3 of 3 Posts
