Hi guys,
I noticed my car was smelling a bit rich and boost levels were a bit inconsistent. Today I pulled the MAF sensor, gave it a clean, went over the boost hoses and tighten them all up and it seemed to make a difference.
First pull was at 60% on the boost controller (5% gain):
Notice how the boost hits it's peak and then starts to drop off?
Second pull - 65% boost 5% gain
Last pull - 69% boost 5% gain
The boost was dropped off again, but seemed to hold on steady after the gear change. Now, am I being a numpty here? Is this quite normal is it is something that needs tweaking in the boost controller (Greddy Profec)?
Any help would be appreciated.
Game Over
That slight drop towards Redline is normal as your running higher boost, because your compressor efficiency is slightly dropping off up top. When I ran 19 psi on pump gas on stock twins, it used to taper off to 16-17 psi towards redline, even with the wastegate spring mod. I made that spring adjustable, tightened it on that actuator as much as I can, backed down the duty cycle on the boost controller, and I made the same 19 peak boost, but I reduced that drop to 18 psi at redline.
Sweet. Awesome news... Something I can forget about now then! Thanks for shedding some light on that mate. :)
Boost Junkie
It also wouldn't hurt to do a boost leak test as well.
Steve
That's the next step Steve, definitely.
