1 - 3 of 3 Posts
Heres the deal.....got my car switched to a 5 speed. the hole i was running the boost guage through was where the master cylinder was so he had to disconnect the hose running to my t-connector that i had installed for the gauge to work...very simple right.....so i find another hole and run it back out to the t-connect and nothing works. not only can i not get the boost gauge to register but i cant get the gauge on the dash to work either .....there is no sucking going on....but my car still boost, though not very hard ........i cant find any holes in any of the hoses......im freaking lost .....this is BS
· 7M POWAH! baby ;)
just plug it into the vacuum line at the back of the manifold... that's where i got mine :)
· Señor Member
Sounds like you didn't hook up your line right. Check your connections and verify there is vac pressure by taking the hose off the gauge. You may have also damaged your hose.
1 - 3 of 3 Posts
