1 - 9 of 9 Posts
i have a autometer boost gauge and it only reads 4-5 psi max dont understand it brand new 57 trimCT turbo and wastegate from PT. With shims i only could reach 6psi. When the car is at idle whats the vac supposed to be. I think im going to try boost controller this week if that doesnt work im going to purchase the HPF IC kit and see if that helps cause maybe i have a leak somewhere. It has to be small cause i just inspected all those connections. And where is the best place to plug in gauge vac line right into the throttle body right.
you shouldnt just inspect the hoses and clamps. you should do a pressure test and check for boost leaks that way.
its ok i fiqured it out with some help. So the guy before me just hooked it up so that the needle would move thank god i didnt shim that wastegate anymore. Cause that thing was pissing me off
what would jesus drift?
it should be hooked up after the tb, on the fire wall side of the intake mani, i found a vaccume nipple..
that seems high for idle vac, unless sup has high vac it should be 15-17 is standard i believe,
Always playing catch up
um more like trent said, 20 is about as least you want (mines at 18-19 cause of a valve seal thats on its way out) anything greater is fine
<l><l>
edit: meant while warm
1 - 9 of 9 Posts
