1 - 3 of 3 Posts
Boost guage is out/ Oil pressure guage at ??
87 MKIII turbo MT
-boost guage just went out. i have started the car for awhile due to several problem, but last season when started up and it worked.
-on idle at ~1k rpm, the oil pressure is at a bit less than 20PSI, is that good or bad??? whats teh normal pressure???
· Dr. Jeff Lange
Oil pressure sounds fine. Check the connector on the boost sensor in the engine bay. Driver's side of the engine bay (up on the inner fender).
1 - 3 of 3 Posts
