1 - 2 of 2 Posts
ok i just got done running an s2k, sooo boost fine and everything, i had just but on a bov, im running the stock one plus an after market just to get more flow but without stalling, after running the s2k, it wont boost over 5psi. any ideas, im going out now to pull the weather guard off to check if i split a charge pipe, but thats the only idea i got, all vac lines are fine.
More than likely IC piping was blown off during the run. a BOV for stock twins isn't necessary and unless you are running the kit for Supras where the air is recirculated then its pointless actually.
1 - 2 of 2 Posts
