·first of all, I have HKS EZ, and a slightly slipping clutch. BPU at 18psi.
while having some fun with my friends on HWY I suddenly realize 25psi on boost gauge! I was sacred so I let off the gas and turned down the EZ control knob all the way to 12'0clock position (which usually gives about 14-15psi) and got 18psi.
however, this only lasted for short while and everything went back to normal.
It happened tonight again though...I made several pulls without touching the EZ setting at all, running 18psi consistantly and suddenly on 1 pull I get 25psi again!
I checked all hoses and everything seems fine..(especially double checked the hoses going into wastegate actuator from EZ step-motor).
anyone has any idea why I get this sudden raise of boost? would slipping clutch have effected my boost level?
this is not just a quick spike of boost, it stays in 25 psi for as long as I'm on the gas and holds steadily.....WTF!?
any help is appreciated.
thanx
Jonas
thanx
Jonas
