1 - 10 of 10 Posts
I did a pressure test today, and air is coming from the front of the valve cover, where it is cracked. I've known about it being slightly cracked for awhile, but should a ton of air be blowing through there in a boost leak test? What does this mean? Valve stem seal job was done 2-3 months ago.
so a leaky valve cover can cause you to not hold boost? and you actually lose boost as well?? how hard is it to replace the valve cover...is there a guide somewhere? any tips and suggestion. I know one is not to overtighten them or else you will crack the valve cover...let me know. Thanks.
1 - 10 of 10 Posts
