I just replaced a bad oe bov with a new one from toyota.. now i get 4.5-5 lbs of boost up from the 4 lbs i got before i replaced the bov. It get about 5 @ 3500 and goes down to ~4.8 @ 5500, i nerver boost unless i go above at lest 3500. The car sounds just fine too.. could it be a boost leak someware, and does that mean i have to take it some ware so they could check. Also im sure the ECU need to be changed out, if i leave it unpluged for about a min the car starts right up (i tryed the EFI fuse and disconnecting the battery, never works.. only unpluging the ECU)
I'm afrade an N/A might beat me :run:
88 turbo supra 5 sp
88 turbo supra 5 sp
