1 - 9 of 9 Posts
Just wondering, before i setup my water/meth kit. What do you guys think is better? Boost pressure switch activated or trigger switch from a piggy back (map ecu/maft pro). On my last setup i used the pressure switch, but i didnt have any other options. IT seems pretty cut and dry that the best thing to do is use the trigger switch since its so easy to set, and one less component to hook up, but is there anything im missing?
Ang
i think so doesnt it have an aux switch? It turns it on when you set it.
no aux out
only aux in from what i read
I know that the MAFT has aux in, so that when an accessory like water injection is activated, you can bump the AF ratio by like 10% across the board, but dunno about the Pro.
so the maft pro couldnt activate nitrous?
Either way im gonna wire it up for the trigger switch, unless someone can give me a reason the boost pressure sensor would be a better way to go?
Ang
1 - 9 of 9 Posts
