1 - 4 of 4 Posts
Bruce Lee wanna be!!!
I'm running a BL67 turbo and I need to turn the boost down. I have a manual boost controller and its all the way turned down and I'm still hitting 20psi is this normal? Is there any other way to turn down the boost so I can put pump gas in there?
Boost controllers can only Increase boost. If you want your boost lower, you have to swap out the spring inside the wastegate for a smaller/lower one.
Thanks, but I actually just swapped out my boost controller with an older one. I put my Joe P. in there and took out my other one...well, now it was only going to 14psi and I turned the knob a tad and I got it to 15psi, good for me I guess. I wonder why the other boost controller wasn't working though? I think the allen wrench screw was stripped out or something!
Ryan
Ryan
Something was probably wrong with the boost controller...
1 - 4 of 4 Posts
