1 - 3 of 3 Posts
Hey Gang,
Seems like I have a boost issue, most likely a boost leak but please charm in if you have any comments. Car will boost up to the psi I set it to but will not hold, it would drop once it hits like 17 psi's. Another weird thing is sometimes the car will go to up only to like .5 bar, and drop and will not let me hit boost. So it's a hit or miss sometimes when trying to hit boost. Car would sound different a times too when I can't hit boost, but when I do hit boost I can feel it but then again it will not hold. Any idea's besides a leak?
I will be changing my plugs ASAP, NGK 6097's
Thanks,
Mike
Boost4fun
Sounds like something is wrong with your sequ setup. Do the temp. TTC to see if this cures it or check also the EGCV. If the car sounds different this may stuck closed from time to time..
Gerd
1 - 3 of 3 Posts
