supra033 said:
i have a downpipe and a bcc and my boost is still .8 bar. anyone know why?
Aaargh...the dreaded boost leak phase. I too had the same problem. The 2nd turbo would not come online. On WOT runs, 4K rpms and above the car would stop making power and just struggle all the way to redline. Turns out to be a tired vacuum hose of the AIC. Here is a pic of the hose(the hose that goes to the top of the actuator) the problem was with the other end of the hose, to the nipple of the VSV. It easily pulled off with a slight tug.
If you are like me, you have made several WOT runs to find out what is going on. Your plugs are probably fouled, the car will start to have a crappy idle. Time for new plugs, NGK6097's
www.sparkplugs.com but fix your boost leak 1st.
Good Luck
