I guess spike is what the problem is called, not 100% sure.
I'll be drivin along and can boost to 12/13 psi fine in first gear... if i make a fast shift into second, somtimes it will hit fuel cut, somtimes it won't. same type of thing... if i'm in 4th gear at a low RPM and floor it, i'll hit fuel cut (14 psi)
what causes this? somtimes it happens somtimes it doesn't? I'm using a 50 dollar MBC right now, but it also happend when I had a Profec B (sold)
what is supposed to keep boost from spiking? on an profec e-01 would I have this same problem *assuming i set it up correct*
_ Justin
Mods: Apex-i Intake, 3" exhaust turbo back (No cats)
_ Justin
