Boosting Problem..Is this normal ??
1112 Views 5 Replies 0 Participants Last post by  vvaddiraja
Guys, here is my problem...
I'm in 1st gear...and i boost upto 14 pounds..I shift the gear, and sometimes it boosts upto 14-15 pounds without any problems, but sometimes i have to be pedal to the metal to get 14psi, otherwise it just sits anywhere between 3-5 psi..I let go of the gas for a few seconds, and its back to normal again. It boosts to 15 pounds with normal amount of throttle..
This happens from 1st gear to 2nd, and 2nd - 3rd, and 3rd - 4th..Is this normal ? I even replaced my stock BOV with the HKS SSQV BOV..
Any ideas, suggestions etc ?? Thank you in advance for your help.
Here are my mods:
Greddy PE Exhaust
Greddy Airinx Intake
RMM Downpipe
HKS SS BOV
HKS EVC EZ Boost Controller
Sorry, i forgot to mention that i have the HKS InterCooler HardPipe Kit too.
No idea what this could be ?? That sucks !!!
I think its just the way EZ works. I have it also, and since its almost like a manual boost controler, everything can effect its boost output. to get full boost, of course you need to go flat out,
I am assuming you are on HWY when you get 3-5 psi pushing the gas slightly cuz the engine load is building the boost for you.
If you are running sequential setup, than I think you are doing just fine, dont worry unless you start getting low boost.
Thanks ZeroSoul ! I appreciate your help !
