1 - 3 of 3 Posts
Found some info on some Bosch injectors for anyone looking for a set of 1600cc that wont break the bank , you can pick these up anywere from $250-$400
Ford Crown Victoria 4.6L CNG injectors
Ford part# F5TE-B5A FJ231
XL3E-C5A
Chrylser 53030518
Bosch Part# 0 280 150 846
0 280 150 837
0 280 150 839
0 280 150 842
Motorcraft #CM4980 (4803)
Accel 74160
FAST 3016000, 3016004, 3016006, 3016008
Marren 05160
GB REMANUFACTURING Part # 82211133
AIRTEX Part # 4G1256
STANDARD MOTOR PRODUCTS Part # FJ231
Bosch
0280150842-1580cc -Indy Blue tops
## unusual 4.5 ohms
( 14mm top, 16mm bottom )
apparently also marketed as -
* Accel 74160
* FAST 3016000
* Marren 05160
* Marren 051600PI ( 11mm rail fit )
US Ford motorsport fit part
Bosch
0280150846 - 1650 cc -white tops
## unusual 4.5 ohms
is reputedly similar as the earlier blue
[ but alcohol, CNG and LPG vapour compatible ]
( some tests rate them as only 1300 cc )
the blue is a ford USA motorsport item, hence the indy term
the white is a specialised alcohol injector, with heavy pintle , a little slower than the rest
Ford PN:
Ford XL3E-C9A / Ford XL3Z-9F593A
motorcraft - MICM4980
US ford CNG fit part
Bosch
0280150839-1600cc -Aqua tops
## unusual 4.5 ohms
[ alcohol, CNG and LPG vapour compatible ]
US Ford CNG fit part
Bosch
0280150837-1580cc-Brown tops
## unusual 4.5 ohms
US Chrysler CNG fit part
And on that note, I just ordered another set, this time of the 837s (the ones you got). Hopefully, all goes well and I won't get another phone call this time.
1 - 3 of 3 Posts
