1 - 9 of 9 Posts
Is it possible to buy a 4 wire bosch o2 sensor and use the original 2jz-gte o2 sensor plug to plug it into the wiring harness? because right now i have a downpipe for my single turbo kit that has a threaded bung for like a wideband and i cant put the stock o2 sensor on. anyone have any ideas on what i can do? or what some of you have done?
well ima cut the original o2 sensor plug off and connect it to the bosch 4 wire o2 sensor. and just screw it in the DP
Discussion Starter · #6 · (Edited)
On the Bosch o2 sensor there is a grey wire.. a black wire and 2 white wires.
Here is the stock 2jz-gte o2 sensor wires. i know the grey one is to the red/black wire the black one to Shielded(whire wire). but the 2 other black wires both go to either the blue/white wire and brown wire. My question is does it matter which black wires go to either wire from the harness plug? both black wires are the same.
T88 YOU
the 2 black wires are for the heater im sure so no it wont matter which way you hook them up
no it will not work. that is a wideband sensor. you need a controller and that wont relay the info to your ecu either costs like 65 bucks to have a flange for your stock one to be welded on btw do you have aem?
its not a wideband, its a narrowband replacement for your stock o2 sensor as it says.
1 - 9 of 9 Posts
