xessped,
When does yours engage? I just istalled the same clutch with the stock flywheel, and it doesn't engage until the peddle is nearly all the way out. It seems to grap and hold just fine, but I would prefer it grab earlier. Any ideas?
Ucntcachme,
If you don't need the holding power of the stage 3 I would reccomend the stage 2. I had one before my stage 3 and it was a ton easier to drive. Now, as I mentioned to xessped, I just put it in. I only have ~225 miles on it, so I am sure it will get better. I am primarily concerned with when it engages at the moment. On the other hand if you have the cash get a Tilton. They make one badass clutch! I just did some research on it.....daayymn. It only weighs 13lb (w/flywheel) and never needs replacement (just a $200 rebuild).
Daniel
