BPU folks in here....
747 Views 3 Replies 2 Participants Last post by  Steve Jarvis
For those of you in sequential, how much boost are you seeing right before the 2nd turbo kicks in?
TIA,
Brian
1 - 4 of 4 Posts
It should be about 11psi on the first turbo. It will drop off a little as it transitions to the second turbo.
Later, Steve
With pulled hose...i hit about .7-.8 bar on the first turbo before the transition.
Actually that is probably .7 to .8 kg/cm2 not bar. This is around 11psi which is correct.
Later, Steve
1 - 4 of 4 Posts
