1 - 7 of 7 Posts
Has anyone successfully installed a brake bias valve? I have done some major upgrades to the suspension and brake system, and now the rears lock up way to early. This makes charging into corners VERY UNSAFE! What did you use, and where did you get it?
Thanks,
LEADED FUEL ONLY
Since you've done suspension work, is the car heavier on the front axle than it is on the rear now? If you have coilovers, that would explain the problem. You may also have the fronts too low in relationship to the rears.
Bottom line is your rear axle is getting too light in a braking situation.
Does your supra have ABS?
if it does, will these valves work with the system, or will it freak out? My guess is the latter.
If you don't have ABS, sounds like a great solution. Even better would be a way to adjust this bias 100% Front for burnouts...heheh...
1 - 7 of 7 Posts
